Disables the RADIUS client.
| mgmt-access | Specifies the switch management RADIUS authentication server. |
| netlogin | Specifies the network login RADIUS authentication server. |
RADIUS authentication is disabled for both switch management and network login by default.
Use the mgmt-access keyword to disable RADIUS authentication for switch management functions.
Use the netlogin keyword to disable RADIUS authentication for network login.
If you do not specify a keyword, RADIUS authentication is disabled on the switch for both management and network login.
The following command disables RADIUS authentication on the switch for both management and network login:
disable radius
The following command disables RADIUS authentication on the switch for network login:
disable radius netlogin
The mgmt-access and netlogin keywords were added in ExtremeXOS 11.2.
